08-30-2022 11:24 PM
Hi-
Brand new Lucky Mobile user using the very basic $15/month 100 Minutes Canada-wide Calling Plan with Automatic Top-up. I'm using an old iPhone running the latest iOS update (iOS 15.6.1).
I can send and receive messages to other iPhone users using iMessage.
I can receive texts from Android users.
The problem is: I cannot respond to Android users' texts. I receive a "message not delivered" warning with a red exclamation point.
Apple describes the issue here: https://support.apple.com/en-us/HT204065 but when I click on the red exclamation point, there is no option to "send as text message." I can only "try again"
Two bars of cellular service.
I have reset the network and restarted the device. I have tried to set the APN settings, but there appears to be no option to do so in iOS 15.6.1 - or, at least the instructions here: https://www.luckymobile.ca/support/phone/access-point-name are impossible because there is no Step 4 "Select Cellular Data Network" or options for Step 5
08-31-2022 11:57 AM
Update: problem on our end was solved. Phone now works, but instructions on setting APN should be changed by Lucky.
08-31-2022 11:57 AM
09-02-2022 03:45 PM
Hey there @ZAP,
That's awesome news. In order to help other Community Users, can you share the steps that were taken in order to update your APN settings.
Looking forward to hearing from you.
09-06-2022 10:03 AM
Agree and can you update your instructions?
03-13-2023 08:25 PM
My kids both have iPhones and both of them are unable to receive and send texts (either iMessage or SMS) when not on wifi. Both of them have cellular activated and because of the updated firmware I am unable to change any APN settings, seriously thinking of cancelling both accounts because I am unable to reach them when I need to. Help!
09-24-2023 09:06 PM
My Iphone shows that text messages are sent, but none of the recipients are actually receiving the text message. I have tried to send to all my family members, and to android and Iphones. None of them are getting my sent messages. Any idea how to fix this? Phone calls work and internet works also. Just sending texts are not.
09-25-2023 10:37 AM
Can you help with my issue?
09-25-2023 06:03 PM
Hey Lucas,
By the time LuckyMobilePatricia replies, can you go to settings>messages> and turn on "Send as SMS" option. This might be able to fix the issue on the iPhone, as the iPhone might be trying to send the message as iMessage and thus the reason its not going through.
09-25-2023 07:22 PM
Thanks @MK4753 , I checked the settings, and it is already on. Thing is, the issue just came up a few days ago. No issues before that. I didn't change any settings or anything. Taking your advice a step further, I toggled the message settings on and off to maybe try to "reset" it, no luck. It's a mystery!
