- Article History
- Mark as Read
- Printer Friendly Page
on
01-03-2023
11:25 AM
- edited on
09-24-2026
11:23 AM
LuckyMobileAnto
As long as your phone is compatible with our network and already unlocked
by your previous provider. The availability of some services may differ depending on your phone.
Your phone must be compatible with LTE AWS (1700 MHz) or LTE 700 MHz bands, or UMTS/HSPA compatible on 850/1900 MHz bands.
See your phone’s user guide for information about network compatibility.
Starting March 2027, devices and services that rely on Lucky Mobile’s 3G network
will no longer be able to make calls (including 9-1-1), send texts, use data or access other 3G network services across Canada after this date. To stay connected, check your device compatibility and upgrade if necessary.
Not sure if your device is compatible with Lucky Mobile’s network? Check your device compatibility
