17% helpful (1/6)
Lucky Mobile voicemail takes messages when you can’t answer the phone, and can store 5 messages of up to 1 minute each. Unheard messages will be stored for a maximum of 5 days.
Setting up your voicemail mailbox
The first time you use Lucky Mobile voicemail, you’ll be asked to set up your voicemail mailbox.
1.    Access your voicemail mailbox by pressing and holding the 1 key on your mobile phone.
2.    Follow the prompts to record your name.
3.    Choose your greeting:
  • Press 1 to use the standard greeting.
  • Press 2 to record a personal greeting.
4.    Choose your password option:
  • Press 1 to turn skip password on.
  • Press 2 to turn skip password off and set up a password.
5.    Your Lucky Mobile voicemail service is now activated.
Important information
For security purposes, it is recommended that you create a personal password and enter it each time you access your voicemail (i.e., turn off the “skip password” option).
Avoid passwords that are too simple, such as 1234 or the last four digits of your mobile phone number.
To access your voicemail from a different phone, such as your home phone, you’ll need to set up a password.
Check out How to access your voicemail mailboxOpens in a new tab or windowfor further information or Calling FeaturesOpens in a new tab or window for a full breakdown on all available Lucky Mobile calling features.
Was this article helpful? Yes No
