Calls drop or sometimes cut in and out.
Chappie59
Hi.  I live between Kingston and Middleton, NS and sometimes my calls drop in the house or cut in and out.  Is this area bad for that?
Chris
2 ACCEPTED SOLUTIONS
Hey there @Chappie59
Welcome to the community and thanks for your post.
The Community being a peer to peer assistance channel and not having direct access to your account would make it hard to determine these kind of things.
However, we can confirm that usage within a house, basements, buildings, underground parking lots, etc. can affect mobile reception.
  • Are you experiencing the same while being outside?
  • Have you reached out to our technical support team to get the location verified (only if services outside is also affected)?
In order to contact our technical support team (only if services outside is being affected as well), check out the Contact UsOpens in a new tab or window page on the LuckyMobile.ca website.
3 REPLIES 3
How does one contact the technical team?
Chris
