How can I view my previous posts
MammaK
Contributor II
Is there an option for us to view the post that we have made on the luck in Mobile community forms? I'm trying to find an older post of mine but it's proving impossible to locate and I can't find an option to search my own post. If there is nothing, something should be added for this
Hello @MammaK
You can view your Profile, Community Stats, Badges and all Posts/Replies by clicking either your own username on any of your current posts or by clicking your avatar in the top right corner and selecting My Profile.
Older posts may have been Archived. Posts are Archived from time to time to keep the Community clean, organized and up-to-date.
1 REPLY 1
Hello @MammaK
